1 - 10 of 10 Posts
Yamaha claims improved gas mileage on the new 2012 Stryker and other models including the Raider. They claim from 42 mpg on the 2011 to 48 mpg on the 2012 Stryker. And from 42 mpg on the 2011 to 51 mpg on the 2012 Raider. It's already hard to believe the Raider having a bigger motor and weighing a 100 pounds more than the Sryker gets the same or better mpg than the Stryker. Is this true? If so what did they change to get this increase in mpg? And dose it compromise hp an performance? Did they change compression ratio or what? I would love to do this mod to my bikes unless it decreases hp and performance. Any one got the 411 on this so called improvement?
I can't find anything on the sight that indicates that any of the specs or features have been changed or modified that would improve the mpg like reduction of weight or change in compression ratio or full injection system. So is this just BS to justify the increase in price from $10,599-$11,240 on the 2011 models to $12,599 on the 2012 models? The only changes I see is 3 different color combinations. Any body else find out any thing else please let me know. Again this sight claims an 8 mpg improvement from 40 to 48 mpg. http://www.yamaha-motor.ca/products/products.php?model=3938&section=ft&group=M#contentTop
With the exception of them talking about a canadian version... I see where they say 17KPL or 40mpg "imp"... But the U.S. advertise everything i the same except for cosmetic differences... Official Star motorcycles specs:
MSRP* $11,340 (Reddish Copper) Available from September 2011
$11,340 (Candy Red) Available from September 2011
$11,090 (Raven) Available from September 2011
ENGINE
Type 80-cubic-inch (1304cc) liquid-cooled V-twin; SOHC, 4 valves/cylinder
Bore x Stroke 100.0 x 83.0mm
Compression Ratio 9.5:1
Fuel Delivery Fuel injection
Ignition TCI: Transistor Controlled Ignition
Transmission 5-speed; multiplate wet clutch
Final Drive Belt
CHASSIS
Frame Steel double cradle
Suspension / Front Telescopic fork; 5.3-in travel
Suspension / Rear Single shock; 3.9-in travel
Brakes / Front Hydraulic disc, 320mm
Brakes / Rear Hydraulic disc, 310mm
Tires / Front 120/70-21M/C
Tires / Rear 210/40R18M/C
Wheels 5-spoke cast aluminum
DIMENSIONS
Length 99.6 in
Width 33.9 in
Height 44.5 in
Seat Height 26.4 in
Wheelbase 68.9 in
Fuel Capacity 4.0 gal
Fuel Economy** 40.9 mpg
Wet Weight*** 646 lb
OTHER
Warranty 1 Year (Limited Factory Warranty)
ENGINE
Final Drive Belt
CHASSIS
DIMENSIONS
Length 99.6 in
Width 33.9 in
Height 44.5 in
Seat Height 26.4 in
Wheelbase 68.9 in
OTHER
Here is the info from the sight . At the bottom of this page is the claimed mpg imp.
$12,599 msrp*
Overview
Technical Details
Features
Accessories and Apparel
Gallery and Media
Payment Estimator
Extended Warranty
Parts Catalogue
Locate a Dealer
CRUISER:
Select Model
COMPARE THIS MODEL TO OTHER YAMAHA MOTORCYCLES AND SCOOTERS
JUMP ON
THE YAMAHA PROFILER!
2012 Stryker
Minimalist design, aggressive attitude
ENGINE:
1304cc (80 cubic inch), liquid-cooled, short stroke, SOHC, 4-valve per cylinder, fuel injected, 60° V-twin powerplant pumps out impressive power and torque for excellent cruising performance.
Uneven firing interval, bore & stroke dimensions and special ignition & injection mapping all contribute to excellent torque output and that classic V-twin pulse feeling
Liquid-cooling not only allows for higher state of tune because it maintains more stable operating temperatures, but also reduces mechanical noise for a quieter engine.
In an effort to maintain the classic air-cooled appearance of the engine, cooling fins have been added as a styling highlight.
The short stroke engine design reduces the "height" of the engine, while the 60 degree "V" makes the engine more compact thereby centralizing mass and lowering the centre of gravity for lighter, more responsive handling.
One-piece cylinder heads feature 4-valves per cylinder to provide optimum breathing efficiency for maximum power output.
Stylish chromed cylinder head covers.
The SOHC valve train features 36mm intake and 32mm exhaust valves with special single coil springs for great power and torque. Valve angles are set at 20 degrees from centre.
Specially designed roller rockers activate the valves. The roller rocker system allows a greater amount of valve lift without causing excessive camshaft wear and friction. The slipper portion of the rocker arm features a needle bearing which reduces wear and slide resistance (friction). The camshafts have been specially designed for use with roller rockers.
Pent roof combustion chamber design and optimized squish area forces the fuel / air mixture toward the centre of the combustion chamber for more complete combustion and hence improved power and cleaner emissions.
The radiator is mounted between the front frame down tubes to minimize its appearance especially when viewing the machine from the side. Even the rad hoses have been discreetly placed for a cleaner appearance. An electric fan aids in cooling during hot weather or in stop and go traffic.
Automatic hydraulic cam chain tensioners reduce mechanical noise and simplify maintenance too.
Ceramic composite-plated cylinders provide uniform heat dissipation while also reducing friction and weight. The cylinders have a tapered "V" appearance to highlight the V-twin design. Cylinder bore is 100mm.
High performance forged pistons offer great durability and reduced weight for faster engine response and less mechanical vibration.
Crankshaft features a single crank pin design. This specially designed crank and uneven firing order helps to enhance the pulse feeling and that unique V-twin engine character.
Single axis, left and right dual engine counter balancers reduce vibration to a minimum while maximizing rider comfort.
Crankcase design features internal oil and coolant lines for a clean, air-cooled engine appearance. There are special piston coolers that spray oil at the under side of the pistons.
Easy access, spin on type oil filter is located under the engine. There is no need to remove any parts to access the oil filter.
Classic side mounted air box houses a high-flow viscous paper-type filter and adds that special styling touch too.
Mikuni dual bore, 40mm throttle body fuel injection system with TPS (Throttle Position Sensor) and ISC (Idle Speed Control). This is a "closed loop" system that utilizes an oxygen sensor in the exhaust. The sensor "sniffs" the spent exhaust gases and feeds back info to the ECU which in turn adjusts the fuel/air mixture for maximum power with minimum emissions. The oxygen sensor is located before the mufflers, so the use of slip-on mufflers will not affect this system. Each injector features 12 holes and a dual spray pattern for better fuel atomization and more complete combustion chamber filling. There is one injector per cylinder. Fuel injection benefits include improved fuel economy; choke less operation, reduced emissions, and great throttle response.
High pressure fuel pump is located in a separate sub tank below the seat.
2 into 1 into 2 exhaust system features dual slash cut mufflers which provide a specially developed exhaust note that accentuates the V-Twin rumble. The engineers call it the "sound of acceleration".
A 3-way honeycomb catalyzer is located at the entry point to the mufflers. The catalyzer reduces harmful exhaust emissions.
Smooth-shifting, 5-speed transmission with 5th gear overdrive delivers outstanding cruising performance and reduced rpms at highway speeds for comfortable cruising.
Clean, quiet belt drive system is extremely low maintenance and simplifies customization. The belt features carbon cords for extra strength.
Air Induction System (A.I.S.) reduces harmful exhaust emissions (CO + HC).
CHASSIS:
Double cradle steel frame with "open neck space" provides an aggressive chopper image. This frame utilizes a rigid engine mounting system to optimize the overall rigidity balance of the chassis for superior handling. The rake is 34 degrees with a yoke offset of 6 degrees. The frame not only provides excellent handling and roomy ergonomics but also compliments the beautiful flowing lines of the entire machine.
Important Note: Raked out front fork with lots of trail generally provides good straight line stability but often results in heavy steering at low speeds. The engineers at Yamaha will not sacrifice handling for styling, so they have developed a 6 degree yoke offset angle combined with a 34 degree steering head for a total fork angle of 40 degrees. The "Stryker" provides light "athletic handling and easy steering" not normally associated with a custom styled bike. This bike was designed to be ridden ! Key numbers: 6 degree yoke offset angle, 34 degree caster angle, 109mm of trail.
Steel swingarm compliments the frame and the overall chassis rigidity balance
Long 1,750mm (68.9") wheelbase creates a long, low profile and solid, stable handling. This chassis offers a 45% & 55% front to rear weight distribution and is approximately 60mm longer than the standard V-Star 1300.
The long low design means spacious ergonomics with lots of leg room, which maximizes rider and passenger comfort.
Raked out 41mm front fork offers excellent ride comfort and compliance. Chip protectors help to prevent stone chips in the tubes. Front wheel travel is 135mm (5.3").
Monocross style, spring preload-adjustable, single-shock, link rear suspension centralizes mass for agile handling. The linkage system provides a rising rate effect that provides excellent compliance on both small and large bumps. There are 9 positions of spring preload adjustability to suit rider preference.
Rear shock is vertically mounted behind the engine and is tucked out of sight for that classic, clean, hard tail look. Rear wheel travel is 100mm (3.9").
Single, large 320mm, floating front disc is squeezed by a compact twin piston front caliper.
310mm rear disc brake is squeezed by single piston caliper mounted to the underside of the swingarm. This design not only helps to hide the caliper but also lowers the centre of gravity for excellent handling.
Lightweight 5-spoke cast aluminum wheels are fitted with tubeless tires. These stylish wheels are both easy to clean and maintenance-free. The front wheel is a MT3.50 x 21 inch while the rear is a wide MT7.50x18. The narrow front tire (120/70 x 21) and wide rear tire (240/40R18) enhance the chopper styling image.
1 inch handlebars are mounted directly to the upper handlebar crown without the use of traditional handlebar holders. This design accentuates the chopper profile while also providing an aggressive riding position.
Deep-bend front and rear fenders enhance the chopper styling. Steel material allows for easy customization and painting if desired.
15 litre teardrop shaped fuel tank with chromed filler cap. The long, slim tank design accentuates the bike's muscular styling lines.
One piece rider and passenger seat offers a low 670mm (26.4") seat height and great styling too. Seating position is best described as sitting "in" not "on" providing a very special "riding attitude".
Chromed handlebar-mounted instrument features an analog speedometer, digital odometer, dual tripmeters, fuel gauge, fuel reserve tripmeter (counts kilometres since the fuel went on reserve), clock, and a range of warning lights and self diagnostic functions.
Instrument functions can be "tabbed" through and reset using the RHS handlebar switch gear, allowing the operator to change instrument meter functions without taking hands off the bars.
Compact 60/55 watt high intensity halogen headlight emphasizes the "chopper" image.
Eye catching LED taillight is not only very visible but also uses less electrical power than a conventional bulb style taillight.
DETAILS
Industry-leading Star family fit and finish features rich, lustrous paint and extensive chrome accents creating a machine as stunning as it is powerful.
Extra wide front brake and clutch levers provide a quality feel.
Steering lock is integrated into the main ignition switch for extra convenience.
Low-maintenance, sealed battery ensures fuss-free, dependable starting.
Self cancelling turn signals with stylish clear lenses.
25,000 km valve adjustment intervals
Specifications, appearance, and price of product are subject to change without notice.
* MSRP does not include freight, PDI (Pre Delivery Inspection), pre-rigging (boats), or taxes. Dealer may sell for less. See your local dealer for out the door pricing.
Highlights
Fuel Consumption ± 17kpl/48mpg(Imp)
1304cc fuel injected V-Twin
Chopper inspired styling and attitud
I should have elaborated... "IMP" means Imperial.... it is slightly more than U.S.
Imperial MPG are Miles per gallon where the gallon is an imperial unit. Imperial gallon is approximately 4.55 litres, compared to the US gallon, which is approximately 3.79 l. Yet, this Imperial MPG is using the same mile as US mile (approximately 1.609 km).
These units have been in use in the UK and Canada to describe the fuel efficiency of a vehicle. The greater the number of MPG, the less fuel that is required to cover a given distance.
Discussion Starter · #9 ·
Thanks SFCMcGan for clearing that up fore me so that's why the sale price is higher cause it's not a USA sale price I take it? But there is still the question about the Raider getting better mpg than the Stryker. How is that possible with a bigger motor and a 100 more pounds than the Srtyker?
just because an engine is bigger does not mean it gets less gas mileage...different tuning... can give it better mpg.. sometimes a bigger motor has better combustion efficiency. lots of variables.... but you cant always believe advertised mpg... almost always calculated in a formula rather than actual testing...a manufacturer will get away with the absolute lowest standard of truth possible....sad really.
1 - 10 of 10 Posts
