1 - 9 of 9 Posts
I find it easiest to do with bike jacked all the way up(no weight on rear tire) and then take small right side plastic cover off( the one with the Star logo). Then take long slim rod and you can easily move adjustment ring. Super easy with lowering spring installed. with lowering spring- I found upper most notch(#9) the best if you have a passenger and luggage. otherwise it is bottoming out on rubber bumber on shock shaft.
thanks for the info...
I used a long ladyslipper, but just a 1/4" rod 12 inches long would work. just tap lightly with a hammer while other end of rod is against one of the holes in shock collar. And yes- almost impossible to do with supplied tools and with weight on swingarm. I will take pic this weekend and post it when I do my other mods this weekend!
The stock shock in the factory position is stiff, unload and turn spring while you turn adjuster it helps. Unfortunately in my opinion, the bigger problem is that the factory shock dosn't have enough damping for the factory spring! So even after you lighten the preload it'll still be slightly bouncy???
1 - 9 of 9 Posts
