1 - 20 of 24 Posts
In my opinion they don't look much different from the stock ones. But I've been thinking about changing my bars also but I'm looking for straight bars without any bend tword the body..kinda bobber stylish. Just my opinion sorry I couldn't help lol
I want something plain and simple for bars...
12 inch though...no bigger
yea, they are pretty similar but i want to ditch the speedo and the stockers are a little funky. So with those bars in the pic above do you just get risers?
i'd like to see how that bolt speedo works and if it is a easy conversion. i was planning just an aftermarket speedo and add turn/neutral/etc. lights. I do like all the functions on the stryker speedo though.
I bought these 4" risors to go with my black handlebars. they are a little beefy , I had to have them milled from the outside to 1.25 wide and 1/8" in. The handle bars are 1' to 1.25 thick.
Handle bars 400
risors 170
mill work 75
brake cable 80
throttle and clutch cables 140
electric wire kit for homeruns 80 bucks
chrome bastininni grips 170
black bolt speedo with mount 315
2x24 pack if beer 50
then we start with the sissy bar from Ginzchoppers.
Handle bars 400
risors 170
mill work 75
brake cable 80
One expensive front end!!!
Discussion Starter · #14 ·
Handle bars 400
risors 170
mill work 75
brake cable 80
did you get 1.25" bars? i'm hoping to find some 1.25's that will work. how hard do you think it'll be to wire in that speedo? and did you drink all the beer?
I believe the speedo will be ok, your only going to the headlight. The handle bar wiring will be a challenge. Im just gonna take my time and do it. I'm not not splicing, doing direct runs. I still have to buy a tool to make the pins for the connectors. It probably wont happen till the weather is bad for about 2 weeks....
If you look at the bars they are 1" at the grips so I dont have to change out ALL of the hardware.
Any update on that Bolt speedo?
Ok I like these ... now to figure out how to mount the speedo. I took a good long look at the 1300 deluxe speedo, and it looks like it is similar to the stryker speedo only mounted to bars that use actual separate risers.
i just did a qucik ebay search and didn't see any, do you have any pics?
If you look closely you can see that the speedo for the 1300 deluxe actually bolts up to the risers that hold the handlebar. The shape of it is similar to our stryker speedo. I was thinking that at some point one could just buy the risers and speedo mounting system and perhaps our stryker speedo would fit right into it... then handlebars of your choice that would affix to risers like these?
1 - 20 of 24 Posts
