1 - 15 of 15 Posts
I have been looking around at options for the air filter intakes and there are a few options. Wondering if you have replaced your stock setup, would you kindly post a pic and put down any pros or cons you have noticed . Thanks
If you use the low and mean adaptor them the possibilities are nearly infinite since you will be able to use any air filter designed for harley and American cruisers
Sent from my GT-N7000 using Tapatalk 2
I'd really like to go with a Kuryakyn Hypercharger (painted black) - but I am unsure how to make it fit even after going back through older posts. ALthough I do still like the look of the Cobra PowerFLo
AXORR~ Correct me if I am wrong but I belive that the Kuryakyn Hypercharger is for carburetors.
The Cobra PowerFLo is for fuel injected systems.
I would recommend the Cobra PowerFLo over the big air intake anytime. I have had both.[/QUOTE]
Kuryakyn Pro R Hypercharger 9468 08-10-9468 for the Raider. I don't think they make a carbed Raider
. They are not not showing a listing for the Stryker but I'm pretty sure they can be adapted or if you search you may find the right one.
http://www.yamahastarstryker.com/20-how-tos/1814-help-needed-installing-kuryakyn-hypercharger.html
I put a SScustom air breather on my bike. I liked the classic look of this breather and it was priced nicely. I also have the Cobra slip-on as well as the Cobra auto tuner. The air breather was the last item on the bike. You can hear the air being sucked in. There was a slight but noticeable improvement in the performance. After I put the breather on another person I ride with asked if I had changed something in the exhaust because the bike seemed louder and deeper.
1 - 15 of 15 Posts
