1 - 5 of 5 Posts
I'm looking to install a Scorpio Alarm System on my 11 Stryker, and on my bro's 11 VMAX.
Does anyone know what wiring harness' I should buy?
According to the Scorpio Listings:
A YAM-10 will fit V Star, Road Star, Royal Star, and Up to 08 VMAX.
A YAM-12 will fit Raiders, Roadliners, and Stratoliner.
I'm thinking the Stryker wiring is probably the same as the V Star 1300 rather than the Raider.
Scorpio reps cannot say which one will fit for sure, so... Anyone??
I went to their website and looked it over, and found this in their FAQ:
Q. What if a connector kit is not available for my bike, can I still install the system?
A: The optional factory connector kit is not required to install the system. Each system includes a universal plug-in connector kit that will fit any motorcycle.
Don't know if this helps or not.
RSR
Q: What if a connector kit is not available for my bike, can I still install the system?
Thanks for the help, RSR.
Yes, I do know that the alarm does include a universal harness, but I would have to cut into the bikes' wiring to install.
If I could buy the correct harness from Scorpio (that would fit my bike), it would be plug and play.
No cutting or splicing required. ;)
Bro I'm down with that! It is always better with plug and play.
RSR
Just contacted Scorpio and this is the reply I got
We just recently found out that our YAM-10 connector does work for the 2011 Stryker. I have not personally tested this but we have a customer that used the YAM-10 connector for his Stryker and it worked great.
All of our systems do come with a universal connector harness as well that will work great for your Stryker. There will be no wire cutting necessary with our universal harness. The harness comes with t-taps to tap in to your license plate light and turn signals. One wire will go straight to your battery positive and another will go straight to the battery negative as well. It is a very easy installation even without the plug and play connector. All of our installation and user manuals are available for download on our website at http://www.scorpioalarms.com/support/downloads
I'm going to go with the SR-I900 and order the Yam-10 connector so we'll see how it goes.
1 - 5 of 5 Posts
