One line goes up and over to the top of the throttle body (it's the one closest to the air filter), just pull hose off and cap using clamp that was holding tube. As per another members post, I found a pack of assorted rubber caps at Auto Zone for about $2. The other line goes up to what I assume to be a check valve, which in turn leads to the fuel tank. I just pulled the tube off the bottom of the check valve. Valve is securely mounted, so no further action required. Canister itself comes off easily, but bracket has to be cut off. I haven't cut mine yet, it still looks a lot better.
