1 - 3 of 3 Posts
Hi Guys, I want to install the Atlas Throttle Lock on my 2017 Stryker, however the space between the switch box and the chrome flange (OEM Grips) is not wide enough. Has anybody installed the Atlas with the original grips on the bike, and if so, can you please explain as to how the chrome flange is fixed/moved on the grip. Thanks..
Did you get the Atlas installed? Mine is arriving next week.
Nope. They told me I needed to cut the rubber grip to be able to move the chrome flange so that it would squeeze in. So I returned it and ended up purchasing the BrakeAway throttle Lock. No problems with the install and it works a treat. It also disengages when Hand braking which the Atlas can't do.
1 - 3 of 3 Posts
