1 - 7 of 7 Posts
I know a lot of people have been wondering if the Avon 250 will rub. I just got mine for xmas and decided to put it to the test. I went for a ride with my wife(340lbs combined) down a road I knew had a big dip with a bit of speed and the top of the tire did rub on the fender mount bolt end under the support frame (see pic). It didn’t hit hard but if I would have been going faster then it would have gouged the tire pretty bad.
I have the PCS lowering links and had it down the full 2 inches still using the stock shock. I looked up the travel of the stock rear end and it is just under 4 inches. 3.88 inches if I recall correctly. I measured the tire to frame clearance once I had the 250 in place and it was around 3 ¼ inches. I knew if the bike bottomed out that it would rub, but thought if I tightened up the shock tension to the 7th notch (only 9 total) that it wouldn’t bottom out---wrong.
Fix-in my case I am just going to adjust the links to the 1 inch lowered position and that should give me just enough since I only needed under an inch more clearance in the first place—hopefully. If I had bought the Dunlop which is taller then I would probably have to go back to the stock links.
I probably could leave it as is and just make sure I take it easy over the bumps/dips/potholes, but you can’t always see those coming up when you’re in traffic. It is not worth the chance of messing up the tire, bike, or people riding it.
Pic is a bit hard to see, but you see where the bolt rubbed all the way around on the right side. You can see where I smugged the dirt with my finger on top of the mark.
Thanks for the research MC.
I'm installing the progressive shock with 1" lower in addition to some lowering links at 1". A full 2" drop with a an Avon 240 should be fine, especially since I never have a passenger. I'm not going to even bother with a 250 since you dont get and more width than a 240 when its squished into the stock rim.
I hope this is the trick - no passengers. The wife has no desire to take a passenger, so I'll be the two up ride if need be.
Ya, I posted this before but there's alot of new members. The stock shock has 3 3/4 inches of travel at the rear wheel. It dosn't matter what tire,link,combo you use you need 3 3/4" of clearance from top of tire to the two bolts under the fender so you can never rub. The dunlop 250 just fits, if you grind the frame a little,and the ends of the bolts to flush. Put your tire on, Measure, drop,and measure again to be safe a one inch drop link dosn't allways mean1"exactly, just measure to be sure(safe) Hope this helps.
1 - 7 of 7 Posts
