Axle mount license plate bracket
Custom fabricated axle mount license plate bracket designed and fabricated by STREETBIKESPLUS in St Louis MO.
Material: Aluminum
Finish: Powdercoat flat black (matches stock frame)
Running light: NO
Plate direction: Mounts vertical
The shop measured the radius of the spocket on my Stryker and designed the plate mount to fit perfectly around the sprocket. When mounted the bracket will cover the sprocket in the rear (meaning that the plate mount on the actual bracket is offset slightly towards the bike/tire).
The main difficulty that I had in finding any other aftermarket side mount bracket was the thickness of the bracket that actually mounts to the frame. Because there is not a lot of length left once the axle is mounted, other brackets that were thicker could not be put on the bike and thread the axle nut on correctly. STREETBIKESPLUS designed this bracket to be strong yet thin to allow the axle to slide through this bracket and also thread the axle nut correctly.
Mine is the only one that the shop has fabricated as of right now, but here is a price listing for both powdercoat and chrome finish. *due to custom cutting each bracket the shop is asking a 2-3 week wait on all orders right now* Shipping fees might apply
POWDERCOAT: $189.99
CHROME: $209.99
I might be interested in selling mine and ordering a new bracket from the shop if anyone is interested in it and doesn't want to wait the 2-3 weeks.
More Information
Material: Aluminum
Running light: NO
POWDERCOAT: $189.99
CHROME: $209.99
More Information
