I need to tighten up my belt, but my metric wrenches only go up to 21mm so I have to go buy a couple more. What size are the axle nuts? (both sides)
Thanks in advance.
Thanks in advance.
22mm...i just use crescent wrenches. Put the bike on a stand to get the rear wheel off the ground. Loosen the 22mm axle nut and then adjust the belt tension/alignment with the small 12mm nuts on both sides of the swing-arm. Adjust in 1/4 turn increments equally on both sides as it doesn't take much. What I found helpful is to run the bike in 1st gear...and watch the belt from behind. You want to see the belt ride in the middle of the rear pulley...not hugging the left or right side too much as it will squeak. It can be tricky finding the right combination of both belt tension and alignment. Just be patient and don’t kick the bike over off the stand in a fit of rage! Once you've found the sweet spot torque the 22mm axle nut back to 110lb's BEFORE you snug the 12mm nuts a tad. Then put the rear end back on the ground. Take it for a spin and kill the bike at low speeds to listen for any belt noise or funny vibrations.I need to tighten up my belt, but my metric wrenches only go up to 21mm so I have to go buy a couple more. What size are the axle nuts? (both sides)
Thanks in advance.
that's a bunch of bull sh!twow, you can't even say d**n!!!![]()
Correct!Well- if were going to do it correctly, The mufflers need to come off and torque nut properly.
