1 - 18 of 18 Posts
Here is why I'm confussed .
Quote directions.
(The end with the single hole points to the rear of the motorcycle and attaches to the frame ,the end with the 3 holes points forward.)
The down possition is a shock mount but the shock mounts to the frame. and the up is the swingarm.
If they would of said up or down it would be simple.
yea thats some crappy directions, Look at the PCS install thread. It will be the same except you have 3 holes where as the PCS ones have a cut out to slide to the different positions without taking the front bolt out or bottom.
Discussion Starter · #12 ·
Bozzly said:
clar2001 said:
Bozzly said:
3 holes go on bottom or front however it is written. Single on top or back.
yep thats it thanks :eek:
Anytime Clar, glad I could help. Now when do I get to see pics?
Thanks Bozzly ,I plan on installing saturday morning will post some pics and let you know how it works out.
Discussion Starter · #13 ·
Dog bone install 2 inch drop,placed bike on jackstands used car jack under rear tire undo nuts from bolts on dogbones ,lift tire with car jack untill bolts easily pull out , reverse process for install , hardest part breaking the nut loose, total time maby 30min.
Belt guards with with no moding, bottom was already moded to fit Dunlop 250 tire.
Discussion Starter · #18 ·
Peteystryker said:
Cool let us know. I'm in the same direction.. Picking up the my Stryker from 1st service and 250 rear install..looking forward in dropinng in 2" with the pcs links
I opened a new thread on this Petey every thing worked out good with minual work kinda surprised how easy it was, there has been a lot of disscussion on this.
Basicly just trim the rear of the frame about 3 inches with fender off left tire on ,trimming of lower belt guard for tire and everything else was good, remember I dont have the stock duck taillight that would make problems. It handles much better with the lower stanch or rake to the front again.
1 - 18 of 18 Posts
