1 - 5 of 5 Posts
Due to cable stretch(I'm assuming) the throttle grip is not snapping back like it once did. I've done this a zillion times on other bikes and just can't get it right on the Stryker. Lubed the cable so that should not be the issue. Any thoughts?
Did you change your grips? Maybe something got under it and is causing the throttle tube to stick. Other than that...don't know. The 2 cable system screws me up too sometimes. Maybe you're just having a brain fart!
1 - 5 of 5 Posts
