Was looking at buying the V&H big Radius exhaust for my stryker, and was wondering if the fuel pak is necessary? what would be the consequences of not using the fuel pak? Any answers or suggestions would be great
I think you need to remove the bolts by the seat and tilt the tank to get to the injector connections. Even then it's supposed to be very tight. Small hands or long needle node pliers help.So you made the connection under the seat without removing the tank? I was told the tank had to be removed? I have a 2012 model, Thanks
