1 - 9 of 9 Posts
So i am tryingnto wire up the MCBK420B on my 16 and it has a fairly large amp i need to find room for. Anyone know where I can put this.
Sent from my SM-N960U using Tapatalk
Super Moderator
Without a batwing, I don’t have a good idea.
The only thing I could do was that I got a small front forks bag, put it in there and tucked it in the back under the passenger backrest and passenger seat. Doesn't look bad. I ran the wires under the seat and the inch of wires that I are showing, I used that flexible wire covering you can buy at Mircrocenter or an electronics store. I've seen people put it in a swingarm bag as well.
I'd be worried about enclosing it anywhere because of the heat it will generate. If it is weather proof, I'd make a nice bracket and put it under the lower triple trees...
Discussion Starter #5
Do you mind posting pictures or sending a link to pictures of these solutions.
Discussion Starter #6
There is a flat frame piece I think behind the motor I've been thinking about mounting it there.
And anyone know how to get the seat release cover off i think it might fit under there but it has some special star bolt on mine.
You need a "security" allen wrench. Harbor Freight sells a set for like $7. So, yeah, not very secure after all!! :eek::oops:
Super Moderator
It will not fit under that cover!
I have same model, just older version. I just zip tied head unit in between the open space on handlebars. Had to mount speakers on bars anyway, so mine sits under but in between speakers. Also I have the detachable windshield, so had to mount them more on the “Y” part of bars, but it helps with the sound. HTH
1 - 9 of 9 Posts
