141 - 160 of 164 Posts
I think 11 and I discussed the difference in the rpms in another thread. He has a tach and has swapped both pulleys. Not sure how to search for that thread since cannot remember what we were originally talking about but hopefully 11 will see this and post.
I think the rpm difference was minimal or we were talking about 50, 70, 80 etc. with the 30 tooth and the small difference in rpm's...
Moderator
Discussion Starter · #144 ·
Exactly Billy. Engine just has a better rythm at cruise speed with the 30 tooth. top end, fuel mileage stay the same. I still say bike should have come with this setup just like its Vstar 1300 cousin.
Here's a link to our conversation. Based on 11's info I calculated 2900 & 3300 for 70 & 80mph w/ the 30 tooth. Still way below redline but we need a member with the stock 31 tooth front pulley to post to see the actual difference or someone with crazy math skills to calculate the difference.
My guess is 200 rpms difference which for me isn't enough to offset the additional smoothness you get with the 30 tooth around town etc.
http://www.yamahastarstryker.com/18-mods-accessories/54666-why-use-30-tooth-pulley-2.html
Doesn't the 30 tooth pulley and the 240 rear tire cancel out the higher RPM?
Cannot say for sure. Tire size & front pulley each affect the gearing. Initially 11 and I were discussing if we ever had a 6th gear which I would be a fan of like Yamaha just did w/ the FJR1300 and no new box needed :) !!!!
Really a clever piece of engineering if you haven't seen it and they played around with the gear ratios just enough to tune things nice. That is the type of change I'd like for our tranny. 70-75 on the interstate is not unrealistic and having a 6th/OD gear would make it nice. Granted the Stryker wasn't created as a touring bike but still...
I just swapped my pulley with the 30T from a 2014 Bolt (EB183 2014 Yamaha XVS950). Part number 5S7-17651-00-00. Everything fits as expected. I'm excited to take it for a ride after dinner and see the difference!
Wow, what a difference! She just goes now.
Moderator
Discussion Starter · #151 ·
Should have come stock that way from Yami IMO
30 Tooth Front Pulley To Swap
Hi fellow & gal Yamaha fans! I have a 2017 Yamaha Bolt with 7.000 kms I live in Surrey BC Canada I would like to get together with a Stryker 1300 owner to swap my 30 tooth pulley for your 31 tooth for our mutual benefit. Even if you live near the border in Washington State, if you have the mechanical ability and tools, I'm willing to meet for the swap. You'll end up with more grunt off the line, and I'll stop looking for 6th!
Cheers!
Larry
Really happy with the swap. Should have done this years ago. Like any other part, it is not cheap to do but the results are worth it.
I'd like to get $75, that's what I spent on my 31-tooth (from a Stryker). I too am in MN, Chaska to be exact. Let me know if you're interested and whereabouts you are located in MN to see if shipping even applies. Thank you! - Scotty
What year bike is this pulley from?
Im need a 30 tooth pulley that fits a 2015 Stryker.
I’m in Fergus Falls, about 3 hours away from you. I’m interested if we can work something out.
My bike is a 2008 with the 1300 engine. From what I understand, the engines are the same. I know with my Vstar 1300, nothing changed on the engine throughout the lifecycle of the bike. I suspect the same is true for the Stryker. The 31-tooth I put on my bike was from a 2011 Stryker 1300. I should have take a picture of both, but the only difference is the overall diameter, which is what you'd expect. I had a shop install mine and they said everything went fine on the install. My 30-tooth is in "pristine" condition --heavy, solid forged metal. I don't see how this part could ever wear out in this configuration! (It's well-designed just like the rest of the bike!). Anyway, based on your location, I can check shipping and probably include it in the price. If you want a picture, let me know how I can get that to you. Thanks! ... Cool that we're both in MN! --Scotty
Thanks for getting back to me, I am interested In this part. Is there anyway we could meet up if I was to head that way today? Here is my personal e-mail.
[email protected]
when you respond I will send my cell # and we can set something up if that’s easier?
