1 - 6 of 6 Posts
2013 Yamaha Stryker, 7k miles. Drove my son to school this morning when check engine light came on while on a stop light. It will go away when I start to drive but every time I engage the clutch, the CEL will appear. Release the clutch and CEL goes away. Got home. Turned OFF the engine. Then I noticed that now I can start the engine just by the Engine Stop Switch without using the Start Switch.
I have installed led lights on the bike about 3 months ago but I don't think this should cause the problem.
Anybody know what could be the cause of the CEL? Is there a diagnosis tool for motorcycles to read the CEL error code similar to cars?
thanks,
StrikerOut
Administrator
I have heard something like this but not that you can start the engine with out pushing the start. Maybe the switch is stuck and sending a signal.
Discussion Starter #5
The starting issue is due to Starter Switch getting stuck. Pulled it out and it works fine now. The CEL just went away by itself so I do not know what caused it. One other person posted that it could be the air sensor. Thanks anyway.
1 - 6 of 6 Posts
