1 - 10 of 10 Posts
I have a plate relocating mount that I want to install. Removing the rear axle nut, is it just remove and reinstall? Will the axle shift when the nut is loosened? What size is the nut? Do you need to secure the opposing nut on the throttle side? What is the torque after reinstall? That is all. Thanks for the help.
You have to loosen the throttle side, then it slides out to the clutch side. The bike needs to be supported to get the weight off of it. When you put it back on make it "Two Hand Tight!" you dont want it coming loose. The manual on the forum should have actual torque.
1 - 10 of 10 Posts
