1 - 4 of 4 Posts
Hi,
I'm a french biker with a Yamaha XVS 1300 Custom bougth in 2014,it is the same bike than Stryker but sold under another name in Europe.
I've bougth a Denali M5 led Headligth to improve the light but the low beam/high beam spots didn't work as expected, and I don't understand why.
Indeed in low beam mode it should be an halo, a central light and two spots on:
123569
In high beam mode, two others spots should be on:
123570
My issue is that just halo and central light are on in low beam mode (missing 2 spots):
123571
and the 4 spots are on in high beam mode (should be just 2):
123572
As a consequence, low beam mode is not enougth luminous (the first 20 meter of the road are not lighted at all) .
The wire connexion seams to be fine:
Bike Wire <--> M5 Wire
black <---> black
green <-----> blue
yellow <----> red
Wire connexion:
123573
I've contacted Denali support some days ago , but still waiting a response.
Any ideas of what's wrong ?
thanks and hopping my english is understandable.
Bye
Pierre
Administrator
I know in USA green wire is low beam. Not sure if that helps?
hi,
Denali support answers me it was the expected behaviour because I have an E Mark model (European standard), and not a DOT model (USA standard).
Quite suprising answer because it doesn't light the road at all on the first 20 meters.
I will add extra spot led to counterbalance its.
Administrator
Thanks for posting the reply and solution!
1 - 4 of 4 Posts
