1 - 5 of 5 Posts
I’ve been running the Custom LED taillight for quite a while now. This past weekend my dad and I were riding and he brought something to my attention that I hadn't noticed. On our ride I discovered my factory horn was only working intermittently so I kept pressing the button to see what the deal was. My dad said every time I honked the horn my taillight would do a quick strobe as if I tapped the brakes. Is this a built in safety feature with the Blaster X technology of the light or is something up here? The strobe effect doesn't happen if the horn doesn’t work...only when the horn sounds it does it.
kraaazymike said:
where did you tap in the ground wire for the Custom LED strobe light?
Mike you don't have to ground the light because the 3-wire harness plugs directly into the OE motorcycle harness. There is a gray wire you can ground if you want to use the customizable strobe features but I didn't want to do that so I left the gray wire unconnected per the instructions.
1 - 5 of 5 Posts
