Wow. That seems too fast. I shift down at 10 or 12mph or soSCHIMBO said:
Wow. That seems too fast. I shift down at 10 or 12mph or soSCHIMBO said:The manual says to downshift from 2nd to 1st at 19 MPH. hope this helps
So your Stryker has synchros? :-X8sec-z said:Exactly.MY said:Everyone has it pretty much right. Its loud on most bikes because of going through neutral. Also if your RPM's are to high while your shifting down, it will only make it worst.
Blip the throttle when you pull the clutch in and downshift. It will downplay the the clunking thing cuz ur speeding up the trans shaft/synchros and that little blip will cause the clutch discs to seperate from the plates a little better than simply pulling in on the clutch lever.
Make sense?
After reading this post and watching my speed more for 1st gear that 19mph really makes a difference. tks.SCHIMBO said:The manual says to downshift from 2nd to 1st at 19 MPH. hope this helps
