This is my first belt driven bike/road bike. I have had a yamaha R6 and a ZZR 1200. With that being said I'm not sure if the problem I'm having with my Stryker is just a normal occurrence or an actual problem...
When the bike is in gear (any gear) and you accelerate or decelerate I'm getting am initial bucking every time both ways. Just as an example, while in 3 gear at about 40 miles per hour, if I roll off the throttle I get a slight buck as if there was slack in the drivetrain or clutch. The same with accelerating from 40 mph at a coast when I roll on the throttle I get a slight buck. It is not only at this speed/gear. More like every speed/gear unless I'm in 4th or 5 th at a higher speed, and then it isn't really noticeable. Thoughts?????
Thanks!
Thanks!
