If I were going to do it I would first start with determining if the Stryker frame would accept the Raider triple trees and go from there.5mm is .197". Not sure how much strength that would take away from the triple trees.
Agreed- And also we get to show off more of our front wheel bling than the Raiders are able to.If I were going to do it I would first start with determining if the Stryker frame would accept the Raider triple trees and go from there.
I wouldn't mill anything from the Stryker trees and certainly not almost two tenths of an inch, That's just under 1/4"
IF... I were considering doing it that is...
I'm not!
My bike stops just fine!
I rarely use the front brake. Thats just how I roll!
I wonder what kind of aftermarket front disc we could find that has some better appeal looks~wise?The single disc looks weak, but I love that it shows off the wheel. Too much of a hassle to change out anyway![]()
if your coming from a front 2 disc bike, there is always that question about the single disc. I just got used to it, its fine.
Not necessarily THIS one but you get my drift?
If you don't have this by the end of the summer, you are dead to me.I wonder what kind of aftermarket front disc we could find that has some better appeal looks~wise?
That is beautiful! I want to add the Low and Mean front fender and radiator cowl! I like the chrome pipes but I've been kicking around the idea of some Cobra swept back pipes with that angle. I looked at some "Curb Burners" but it's hot enough as it is! I think I will just add a steel braided brake line and see if that helps. Back brake locks up real easy on hard brake and down shiftIf I were going to do it I would first start with determining if the Stryker frame would accept the Raider triple trees and go from there.
I'm not!
