1 - 8 of 8 Posts
Has anyone got a close look at the new 1300 Delux, i noted from the pictures on the Yamaha sales site that it has Dule rotors. Why won't they put these on the Stryker, considering the power the extra braking sure would be nice.
Steve, ironic you posted this since I was mulling this one over about 1 month ago after reading some post/article. I took a slightly different approach and compared it against the Raider since I think they have the same size front wheel etc. Just from pictures I cannot say if you could remove that one part of the hub on the Stryker and replace w/ Raider parts but since you and Patrice will be working on hers soon take a look.
Mine is buried in the back cubby hole so I was waiting till spring or the MC show/trip to Rich's to take a closer look and decide.
If the parts are bolt on(and like I said I can't get in there for a close look) I'd like to think the job wouldn't be too difficult.
Again assuming the above is true you just have decide if the part costs are worth the increased stopping power. You'd need an additional rotor, new line(s), New master?? and I believe some sort of balancing thing but then again looking at your bike you've probably figured all this out already :D
Another approach might be to look at more grippy brakes. You might get more brake dust, quicker rotor wear and the like but this is by far the simpler of the two jobs!!
Keep us in the loop if you go down this path...
Don't quote me on this but if you wanted to change over to dual fronts on the Stryker - pretty sure you would have to change to a Raider wheel w/rotor and you would also have to change the lower right tube to be able to mount the caliper and add the additional line...it wouldn't be very cost effective...why they didn't just put duals on it to begin with doesn't make much sense.
Yep looks that way. I got curious and crawled next to the wheel and got the bad news. From pictures it looked a little different.
I'm guessing unless you found a wheel intact from a totaled Raider it would be hard to justify the expense of the project.
The duels would be nice but they would cover the wheel as well. Maybe someone already does or down the road will make a bigger rotor to bolt on to the existing mount and give us a little more stopping power.
+1 On the bigger rotor. Lotta pull on that break to get her to slow down quick. I would love to get a larger rotor. I haven't checked around yet but there's probably something out there that can be used. I guess I should get busy figuring it out lol.
1 - 8 of 8 Posts
