engine stalls when put in gear
3292 Views 6 Replies 6 Participants Last post by  Stryker kado
bike starts up with no problem, idles good, but as soon as i put in gear, it shuts down....anybody know what the problem is?
thanks
1 - 7 of 7 Posts
If you put in gear with the kickstand down that will kill it - if the kickstand is up and you put it in gear and it dies it's probably the kickstand switch
Best way to test this is put the bike in gear kickstand up hold the clutch then start if it dont start then you know its the switch :)
Do a search on this as someone posted the problem before and the relevant pages from the owner/service manual. The safety starting switch has multiples paths that either allow or don't allow the bike to be started/rode. Better to read that over rather than me try and recite it from memory.
One other question: "When you put it in gear and it dies, does it lurch before that?" If so than the clutch needs to be adjusted.
The other replies are correct but read over the pages from the manual as knowing how the starting safety circuit is supposed to work will help you troubleshoot the problem.
⁵⁵þþtt⁵þþ4ģf
Possibly the kickstand switch.
not the kick stand switch either tested it
bike starts up with no problem, idles good, but as soon as i put in gear, it shuts down....anybody know what the problem is? thanks
I'm having exact same issues
1 - 7 of 7 Posts
