1 - 1 of 1 Posts
2012 stryker
So today I decided to open the drain plug and let some oil out. I'm totally bewildered how it could be giving me a high reading. ( Only put 3.59 qts in ) .. the sight glass showed it all the way at the top . So after the partial drain I measured the oil that came out .. 21.5 ounces... Wow ! Now - started the bike . Ran for 3 - 5 minutes... no oil light .. no lights at all . Shut it off . Waited a few minutes. With the bike upright ( on a block) the sight glass showed a perfect reading oil at top mark . As time passed by, each minute or so later ( with oil returning to oil pan ) the level started to go up . Check out these pics where you can see what I mean. I'm really confused. What's going on. Am I still high on oil or is the high mark only because the engine is cold ? 🥶
Speedometer Odometer Light Motor vehicle Gauge
Automotive tire Hood Automotive design Vehicle Fixture
Automotive tire Motor vehicle Automotive design Automotive exterior Rim
Automotive tire Fluid Water Automotive exterior Gas
1 - 1 of 1 Posts
