1 - 8 of 8 Posts
When you removed the front reflectors from your Stryker, did you just remove them completely or did you keep the one on the left side and just cut the reflector portion off to retain the brake line clip?
ya same here cut it off.
I still wanted to have reflectors just not those. I got a small set over at BMW that have double sided tape to place on the fork.
I found this thread and wanted to know if it would hurt to remove the whole brake line clip entirely. I installed the Low and Mean front fender and the bracket is too ugly to keep on. If I need a bracket, what has everyone used as an alternative?
I do not have the reflector or the piece they mount too including the brake hose clamp, since i put my new wrap fender on.
1 - 8 of 8 Posts
