1 - 3 of 3 Posts
Administrator
Figure I would share my experience. Time for the front bearings as I had a smidge of play and also a grinding feeling to them when spun. So when you get new bearings no matter where they are from always remove the inner cover sleeve, it’s silicone or rubber and a jewelers flathead works great as you can see from the first two pics these are what they look like from Manufacturer. A tiny bit - definitely not enough.
Camera accessory Material property Cameras & optics Camera lens Font
Automotive tire Font Rim Material property Circle
After a proper packing which includes spinning the bearings for 20 seconds to distribute the lube evenly then I use my finger to remove the excess, because you can have too much! And you want to leave space to put the cover sleeves back on to prevent contamination.
Eye Product Camera lens Font Material property
Font Material property Triangle Circle Packing materials
Automotive tire Camera lens Lens Rim Cameras & optics
  • Like
Reactions: RustyJake
1 - 3 of 3 Posts
