So let me get this straight..............afcop97 said:I'll warn you that you're about to get 15 replies telling you to use the search function....did that when I was new on here. Bottom line from what I've learned on here is that if both your intake and exhaust are aftermarket you will need one to modify the fuel/air mix. If either your intake or exhaust are stock, you should be good without one.
I have the Cobra slip on and the stock air cleaner with a K&N filter and run without one just fine.
Be warned that i had put a cobra slipon and aftermarket filter on a bike without a tuner. Everything seemed to be fine, until a year down the road when i started having problems with the bike ideling, starting, knocking and overheating. I had ran the bike long enough that the engine was toast, i had to do a rebuild. I will never make the mistake of not spending a few hundred dollars on a tuner and in turn spending over a $1000. for the rebuild...afcop97 said:I'll warn you that you're about to get 15 replies telling you to use the search function....did that when I was new on here. Bottom line from what I've learned on here is that if both your intake and exhaust are aftermarket you will need one to modify the fuel/air mix. If either your intake or exhaust are stock, you should be good without one.
It was only a $1000 to rebuild the STRYKER 1300???Mikey76 said:Be warned that i had put a cobra slipon and aftermarket filter on a bike without a tuner. Everything seemed to be fine, until a year down the road when i started having problems with the bike ideling, starting, knocking and overheating. I had ran the bike long enough that the engine was toast, i had to do a rebuild. I will never make the mistake of not spending a few hundred dollars on a tuner and in turn spending over a $1000. for the rebuild...afcop97 said:I'll warn you that you're about to get 15 replies telling you to use the search function....did that when I was new on here. Bottom line from what I've learned on here is that if both your intake and exhaust are aftermarket you will need one to modify the fuel/air mix. If either your intake or exhaust are stock, you should be good without one.
it was my m50, had a local repair shop do it.SFCMcGan said:It was only a $1000 to rebuild the STRYKER 1300???Mikey76 said:Be warned that i had put a cobra slipon and aftermarket filter on a bike without a tuner. Everything seemed to be fine, until a year down the road when i started having problems with the bike ideling, starting, knocking and overheating. I had ran the bike long enough that the engine was toast, i had to do a rebuild. I will never make the mistake of not spending a few hundred dollars on a tuner and in turn spending over a $1000. for the rebuild...afcop97 said:I'll warn you that you're about to get 15 replies telling you to use the search function....did that when I was new on here. Bottom line from what I've learned on here is that if both your intake and exhaust are aftermarket you will need one to modify the fuel/air mix. If either your intake or exhaust are stock, you should be good without one.
My only difference is that I have not cut out the back of the air box. I do have a Cobra Fi2000R O2 on my wish list, but only as a nicety, not something I thought I needed. Only about 1500 miles on my bike so far.SmokenJOE said:All I can say is I have been running my set up for close to 40,000 miles this way and no problems. Cobra slip-on and modified air box with the back cut out and K&N filter. Just do what you can afford or what you think needs to be done is the best answer I guess. :-X
Lmao!!! Why thank you, but I do not expect any leniency at all!!! ;D. lol.11Stryker said:You're a Lady Wyntress! That's why we go easier! LOL
Link works fine!!Mikey76 said:Sweet find. On a side note i am attaching a link to cobra usa's page. On the top is a california model fuel processor. I hope the link works.
www.cobrausa.com/fuel_compare.php?m...yker&product_type= Motorcycle Fuel Management
