1 - 20 of 30 Posts
The first attempt at my bracket was almost perfect. The only change that is needed, is the hole for the air temp sensor is causing it to bind against the triple clamp. My buddy will be machining a new one by the end of the day.
Discussion Starter · #12 ·
SFCMcGan said:
BANE said:
Thanks everyone. This is the one im using in flat black. http://www.trydna.com/v10.html Hopefully.it will be on tomorrow and I can put up some pics.
What size light you going with? Those headlights look pretty sweet!
Its 5 3/4. Once the bike is stored I will take it back off and put a black coat on it. I talked to my buddy he said that once he has the cuts and finish perfected in a day or 2 he will throw something together for anyone interested.
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
Discussion Starter · #16 ·
StrykenShane said:
Yep, I'd be interested as well, do you wear that mask when you ride?
I wear it under the full face in cold weather, I cut the eyes out before I left so I could clear up my vision.
ROADKILL said:
Do you wear those shoes when you ride..................cool bracket.
LOL. That's my buddy Chris in his crocs.
Discussion Starter · #18 ·
I didn't want any of the light hidden behind the forks or ignition cover. I'm sure it will blend better once everything is the same color. I could have a shorter one machined just to see how it looks.
Discussion Starter · #19 ·
Thanks for the idea Jon. Now that I have been thinking about it, I'm going to move the light a little higher to bring the top of the light level with the top of the tank and back to have the tail end of the light cover the bulge on the ignition cover. This way it will be more in line like the Fury and the Hammer.
Discussion Starter · #20 ·
I have been trying a bunch of different configurations and found that moving the light up about 3/8 is where I like it. I will post new picks once everything is black, which should be the end of next week. I wanted to know if there are any suggestions on where they would like to see the light placed? I will get Steve on this site so he can see all your recommendations. He doesn't have the time to tie up his machine to make a different style bracket for everyone, but maybe he will be able to make 2 or 3 different styles. Let us know.
1 - 20 of 30 Posts
