1 - 20 of 32 Posts
Well one thing is how to connect the vaccuum line. The instructions are very short and vague. Overall it's pretty obvious how to mount it, but I think I'm gonna go ahead and take it to a mechanic. The instructions say the carbs need to be jetted and I'm not going to mess with that.
The stryker doesn't have carb, so don't worry about that. Basically on the top of your throttle body ( the place your mount the intake to), you should see a small rubber boot. Pull the boot off and place your vacumme line onto the little dammit sticking up. I do remember the vacumme line that came with the intake was a little big. Just go to our local automotive store and get a smaller one.
Hope this helps.
Ok...so does it just connect it to where the vent line would go?
Also the hypercharger has some kind of plastic ring inside where the filter goes that's just floating around. Not sure what to do with it.
Urbanrage is correct, there is an unused vacuum port with a tiny rubber boot on it. Remove that and put your hose there. I recently installed a hypercharger, and the hose that came with it was the perfect size. If I remember correctly the plastic ring went on one side of the filter to make it fit correctly and not bounce around inside the housing.
I see the port but where does it attach to the hypercharger? Do you just connect it at the bottom right instead of attaching the vent hose? That looks like the only place it could go. And yes, the hose looks like the right size.
Discussion Starter · #9 ·
Got it installed. Thanks for the help guys. This thing looks freakin badass on my bike. I got the stinger trap door to go on the outside....looks sweet.
Now to tackle the power pro install. Thanks again
Pics are a must on here.....I finally got the ol'lady to un-ass some cash so now its my time to get one. Can anyone recommend where to buy it at the best price? I'm looking for the black one to match my raven.
1 - 20 of 32 Posts
