How To Dim Speedometer (Stock) Brightness
1. Turn key to "off"
2. Push and hold the "^" side of the "SELECT" switch
3. Turn key "ON" and then release the "SELECT" switch after five seconds or so
4. Push the "^" side of the "SELECT" switch until desired brightness (or lack thereof) is achieved
5. Push the "RESET" switch to confirm and return to odometer, tripmeter or clock
This is helpful if the battery is disconnected and desired brightness is lost.
