This is how to disassemble your gas cap so you can powder coat it black.
This image courtesy Aelway7
Step 1: Remove two phillips screws on the bottom
Step 2: Remove top casing. Pull straight up to remove to reveal beneath. Notice the orientation of the clasps and two springs.
Step 3: Remove clasps and springs. To reveal below.
Step 4: Remove disk with the square center. To reveal below. (There's an arrow pointing to a small plastic piece that has actually fallen out of where it's supposed to be.) You'll see it's correct location later on.
Step 5: Remove disk with the "+" cutout to reveal below. In green are 4 springs to remove. In pink are 3 plastic pieces to remove. The small dome shaped plastic piece sits below the smaller "Y" shaped plastic piece.
Step 6: Pull up and separate from outside chrome housing. Remove lock door by unscrewing small phillips head screw.
Step 7: Send off to Powder Coater. To reinsall lock door, place door into housing hole. Reinstall parts as numbered below.
Reinstall is in reverse of disassemble.
See video to reinstall of springs and clasps. Tip: While lowering the housing cover, squeeze the clasps inward to allowing housing to fall into place.
