1 - 20 of 24 Posts
Progressive Front Springs part #11-1126
This kit comes with 1-10" spacer, 2-washers and 2 coil springs.
Tools neeed - Half inch drive socket to fit the cap (sorry I can't remember what size it was), rachet and 6 inch extension, 10 weight fork oil. (The reason for half inch is to ensure stability and maneuverability.)
Cover any painted surfaces to avoid dripping fork oil on them.
Jack the bike up and tie it down. If you have a chin scoop you may want to remove it to be sure the bottom part of the scoop is not damaged by the jack.
Raise the jack until the front wheel is off the ground and the forks are fully extended.
Have someone hold the bars while you remove the fork caps. The fork caps are a cast material so take care not to drop them and are about 3/4 inches long in the tube but the top of the cap is only 1/4 where you place the socket. You will need to keep downward pressure on the caps when removing them as there will be a slight amount of pressure forcing back toward you. You don't want to have the socket slip and strip the top nut. You don't want to get smacked with a steel spacer or have the fork cap strip on the last few threads as it comes out. (KEEP THE PRESSURE ON Until you are sure - remember the thread portion is 3/4 long this will help you determine if it is safe to relieve the pressure).
Once the caps are off, remove the spacer and lower the jack to bring the washer and spring closer to the top of the fork. You can remove the washer and spring with your fingers if they are long enough or use a hook or metal coat hanger (caution not to drop anything in the forks or scratch the inside of the tube).
Install the new springs, one end of the spring will be tighter wound then the other it won't matter which end goes in first. (Mine came out with the tight wound portion at the top but I installed mine with the tight wound portion down to be sure there was no noise.
Install the washer (supplied with the new springs), one on each side. When you drop them in be sure they lay flat on the tops of the springs. If they are not flat use a long screw driver or coat hanger to maneuver them flat.
If you lost any fluid during uninstall now is the time to replace it. With the forks compressed and only the spring and washer in use 10 weight fork oil to replace any fluid lost. Having the forks compressed at this point will help you be sure that the forks are evenly filled.
Time for the spacers. The spacer supplied with the kit is only 10 inches long and when split in half will be to short. You will need to reuse your stock spacers and cut them shorter. As a rule of thumb with the forks fully extended and spacer installed the top of the spacer should be flush with the top of the fork tube. I found that this caused the bike to lose some of it's height in the front and be a little to soft.
So with the tubes fully extended and the spacers in, I measured one inch above the top of the tube and cut the spacers there. (Approxiamately 6 3/4 inches - this may vary on yours so be sure to measure.).
Let's button it up - With the forks fully extended and someone holding the bars, place the cap over the spacer and push down. Once the cap starts to seat caution not to cross threads on the cap or over tighten it. I found it easier to use a 6 inch extension to help with downward force and tighten them.
Hey thanks visionary. I'll be adding this to my list. Didn't you get a rear shock too?
I sure did I got the 465-1177 which is the one inch lowered...what a pain in the butt! I will direct you in that case to the low and mean lowering spring install. That is what I used as a reference to install the rear shock.
. I will say the biggest problem was the oil tank, there is not a lot of room to get in at the bolt on the exhaust side. Make sure you have a good solid set of hex keys because the bolts you have to remove in some places are extremely tight.
All in all I don't know how to explain it but the bike feels a lot more solid. When turning or cornering the bike goes over nice and smooth without any diving, the same goes for stops. It feels more comfortable over bumps as well. I have to look into adjusting the rear since I just put it in as it came but I can tell there will be some adjusted needed for two up.
Just let the springs drain for a bit before removing them. Shouldn't really need to add any oil. If you're a little OCD, then add a ounce. :thumb:
Getting mine on Wed.
Installed them yesterday and gained about 1- 1.5 inch on the front. I can't believe how the stock springs were. BUT I also had the bike tied down for about 10 days during my cross country trip. So I am sure that also was a factor lol. I haven't had a chance to ride it yet though. Hopefully tomorrow.
ride height
The thought of good handling entices me for sure. Though with my 28" inseam, I'm very grateful to currently plant both feet on the ground as-is :eek:
Hey Kraaazy- that's 1" at steering head. Our arses are back just ahead of rear wheel, so change in height is very minimal back there.
1 - 20 of 24 Posts
