To remove the Gas Cap Accent you muct slide a putty knife under the Accent piece to separate the 2 sided tape
Tools Required:
Putty Knife (plastic or metal)
Masking Tape (to protect the blade from damaging the tank
You will need to remove the Gas Cap
Then slide the putty knife under the Accent Piece. The 2 sided tape is on both sides front and back.
Once removed, the tape is taken off with either goo gone, or if your lucky you can just roll it off with your fingers.
Tools Required:
