Hey Gang. I'm not one to get on here and piss and moan about everything wrong in the world today but I have to share this.
Because I added a hypercharger and Cobra Dragster pipes to the Stryker, I had to also get a power commander. When you order one and install it yourself, it does not have a program on it other than stock. So what do you do? You call PC and tell them what you have done to your Stryker and they email you a map to upload into the PC. Sounds simple right? WRONG!!!
I did that very same process but once I got in touch with PC customer service, they told me that he could not send me a map because one does not exsist for my add on's. Pipes and hypercharger are not an uncommon add on so I dont get why the **** they couldn't just write a program that would suffice. Never the less, the PC customer service guy told me the only map available that came close to what I had was a map using the air spike intake and Cobra Swepts pipes. I figured "what the ****" hypercharger and air spike work just about the same and open pipes are pretty much the same so that might work. Even the guy at PC said it is so close that there shouldn't be any issues. So we did it and all was well....until....
A few weeks ago the bike started cutting out at normal highway speeds. Not during accel or decel but only at a steady constant throttle. Kind of like a hiccup and was doing it quite often so I decided to head for the shop. The first thing we did was hit the dyno. This shop is a Power Commander APPROVED dyno center and on the first pull, the dyno guy shuts off the bike and comes and gets me, drags me into the dyno booth, and shows me the read out on the screen. The bike is waaaayyyyy to lean. And had I not dealt with it in time, would have lead to some real problems. We spent another 2.5 hours on the dyno and by 6 pm last night I had a perfect air/fuel mixture, timing adjusted properly, and an additional 4.6 horses.....Now I know almost 5 horses dont sound like much but beleive me, I can tell.
Guys listen, At this point I'm not even sure if I wrote this as a way to inform you or just so I could ***** about PC not giving a **** about what maps they are passing off as acceptable, but if you take anything away from this, let it be a lesson. Be mindful of companies and their customer service practices. Especially when it could end up costing you thousands. And if your story is anything like mine, For the love of God, get your ass to the dyno machine.
