1 - 10 of 10 Posts
I was looking at the wiring diagram, but I don't really know what youre looking for. are you trying to splice in under the seat? Sounds like the harness that goes back to the tail light is your best bet. Do you need to know what colors they are?
I have mine apart lemme know whats up if u still need help???? my headlight is discoed and wiring exposed.... i think i messed up my headlight wiring??? i think my highbeams are on the reg switch and the high beam switch is the reg beam????
Here you go. Just find the wire group under the seat that goes to the taillight. It's on the "driver" side of the battery and then runs up under the fender.
The wires are:
black(ground)
yellow (hot)
green(right)
brown(left)
Mentat said:
WLFPAK65 said:
On that note.... Anyone know what color the high beam is for the headlight?? im sure i got my connections mixed up lol gotta cut & splice
Looking at the diagram it looks like hight beam is yellow and low is green
Coo thanks..... What sux is i cant get my headlight to turn on with just putting my key in the ignition.... I actually have to start the motor for the headlight to come on so i can double check because my harness has different colors for wiring & i dont have a filter on and my bike is naked if u look at the recent purchase post..... Ill wait till i get all my parts back then mess with the wiring since im also replacing my front turn signals again....
1 - 10 of 10 Posts
