1 - 10 of 10 Posts
Is there a way to adjust the Shifter Lever? My boot gets stuck between the footpeg and the shifter sometimes, so I was wondering if anyone was able to raise the shifter lever to give a little more room.
Just a heads up in case you dont know, use a wrench to hold the swivel on the end of the linkage when loosening and tightening. Someone else on this forum snapped the linkage because they didnt hold the swivels.
The front is left hand thread and the rear is right hand...there should be a a place to put an open end wrench on the shift linkage to hold it when you loosen the nuts
1 - 10 of 10 Posts
