1 - 16 of 16 Posts
Just a little FYI for all you guys running the Swing-Wing pegs with the PCS 2 1/4" drop…if you take corners like I do you’ll eventually grind the underside of the pegs down to the point where they will no longer swing open. I discovered this yesterday when I tried to swing em out for the first time in a while. I was kind of bummed but I can't lie...I also took it as a compliment 8)
I scrap mine quite often, also
Discussion Starter · #12 ·
Boolshot said:
skwerlee said:
I hardly ever flipped them out anyways. I mainly use them as mini running boards so to speak
I don't flip mine out much either. I was thinking about getting the Iso-wings. They look about the same size as the swing wing when not flipped out. I haven't seen them in person though. And they come in black. Has anyone tired these?
http://www.kuryakyn.com/Products/4162/Gloss-Black-ISO-Pegs-without-Male-mounts
yeah those are nice looking. I'll probably go back to stock or some cheaper replacements once these run their course. I burn through pegs too quickly to be spending big money on them. I picked these swing wings up used for cheap
I got mine used from the forum. I don't scrape mine that much... but since I don't flip them out, I might try the other ones. They should make the pegs with a replaceable bottom portion. Then as they wear down, you can replace a small piece for cheap.
I've been thinking about the dually pegs
1 - 16 of 16 Posts
