1 - 11 of 11 Posts
need more scope as to what you mean.
like the path under the seat or chassis?? or the tie into the battery along with the cut off?
Just finished mine this weekend:
https://www.dropbox.com/s/xnyefd1snycpe7l/Video Oct 16, 12 38 43 AM.mov
and in total dark
https://www.dropbox.com/s/34vci06sp89hoed/Video Oct 16, 12 37 52 AM.mov
For ground effects I have 4 strips (2 on each side) on the frame pointing inward (not on the ground so that a bike jack won't crush them)
For the wheels I have one pod on the inside of the swingarm on the exhaust side, on the front wheel it is mounted above the top bolt on the inside of the fender, on the leaning side.
For the engine I have one on the back of the engine mounted to the plastic wall, one strip underneath the gas tank pointed down, one pod at the front of the tank hidden inside it pointed to the frame, one pod near the foot controls.. and all of that repeated on the opposite side.
And then lastly one pod above the radiator, and one on the floor of the inside of the low and mean radiator cover.
1 - 11 of 11 Posts
