1 - 19 of 19 Posts
Anyone else notice that when you go from neutral down into 1st you get a fairly loud noise from the transmission and feel a simultaneous jolt forward for a split second? I’ve experience this on other bikes but this seems a little more intense than what my sports bikes did. I’ve adjusted the clutch lever according to the owner’s manual but if just seems like the noise and feel is a little excessive. Also when I shift from 1st to 2nd it’s a pretty loud clunk. I wonder if i need to adjust my clutch other than at the lever? May be totally normal for all I know.
Normal for this bike friend, Been posted a few times already. Gets a little better after first service. Just ride the Mutha!! LMAO
are you going from nuetral to 1st while moving, or after you stop. as ive done for years on my harleys, i take it down to nuetral and stop, then kick it into 1st. harleys give a nasty clunk like that also, so i take it as normal. i've never downshifted all the way to 1st gear.
Discussion Starter · #15 ·
Just an update on the loud gearbox. I just had my bud do my 4k service. He took apart and lubed the clutch cable as well as the pivot point on the lever. The service manual calls for 5-10mm of clutch lever free play so that's how I've been running it. My bud prefers to set them about the width of a nickel (1.95 mm)…lemme tell you what…the “clunk” from the gearbox while changing gears is GONE 8)
I really dont get much of a clunk since my first service and adding the performance kits, intake, pipes and processor. I do get a little clickity click or grinding if i shift from second to first to softly. Boy, I hate that sound. It is the sound of a gears life being shortened.. :eek:
1 - 19 of 19 Posts
