Was able to get a hold of an air box to experiment with.
Thanks to prophet187.
It is basically the same as others who have done this mod. Just my version;I cut all around the air box edge just leaving the upper portion to mount a flange to mount a air filter. Using a dremel with a cutoff wheel to do most of the cutting. Somewhat of a mess, but not bad. Then cut away the air scoops and sanded, and sanded, and sanded. Man do I miss working in the machine shop!
Not sure I'll use this but I wanted to give it a try here at home. I think the filter sticks out a touch to far for my liking. Plan to cut about .500" off the tube. What do you folks think?
More photos to come later.
