1 - 6 of 6 Posts
It's just the two screws, but there is a bit of a metal lip / flange that helps keep it tight. Pull hard - but be prepared for it to pop off. Since you've not done it before, place a couple layers of towels over your front fender in case you drop the headlight front when it comes off.
Just watch it - when it does come off, you'll need to stop quickly. The wires are not very long in there!
The bottom did start to come off first, so I got a little plastic scoop, with a straight edge, and worked it around the gap, slowly increasing the spread. When I got it all apart and unplugged, I couldn't find my diagonals to snip the ties on the old turn signals, so had to run to parts store. Thanks for the help, guys.
chuckles
1 - 6 of 6 Posts
