Figured I'd share this with you guys who may be experiencing the same surging you get on decel and at cruising speeds. It definitely made a difference in how my bike runs and it didn't cost me a penny because I happened to have the materials needed lying around.
For the full write-up and background info on why you would want to do this and what it does you can read up here.
For those who are interested in just knowing what you need and what you need to do:
You need a 1/4 watt 820k ohm resistor (or 825k ohm if you can get 1% tolerance resistors) to be spliced inline with the white O2 sensor wire. It is as simple as that.
