I've had my Stryker for seven months now and everything has been great, I love my bike. I just recently noticed that on the bottom of the engine the oil level switch is seeping oil. Its not enough oil to drip onto the ground and it only seems to do it after its been ridden for a while. I am assuming that its only seeping after riding because the oil is hot and it thins out. I have re tightened the two bolts to the spec (7 ft. lbs.) and it made no difference.
I am still under warranty but don't really trust the dealership to do the work as I had a bad experience with them on my previous Yamaha. My next oil change I'm going to switch to a 15W-50 oil as I now use a 10W-40. I am also going to pull the switch and check the O-rings and replace them. Hopefully this will fix the problem.
If anyone has had this problem in the past please let me know what you did to resolve it. Any input is appreciated.
