1 - 18 of 18 Posts
Hey guys,
I have a question; since like a month ago, the Oil red light turn on for like 30 minutes and then just turn off again. The oil level is ok, filter is new and i used Mobil1 synthetic oil (i always use this oil in all my bikes with no problem).
Do anyboydy knows the reason and solution ?
Thank you,
Ride Safe!
Fill oil to top of sight glass with bike setting level and see if that helps.
Mine started doing it after my 4000 mile service, at least thats when i noticed it. I asked the guys at the Yamaha shop and they told me it was common for them to come on when you first start it up for a few seconds. My garage is in the back of the house so I ride it around the house and it comes on every once in a while but never stays on that long.
i was just reading other people comments about this issue. I was a little scared, but i will fill it up all the way and keep watching it.
Thanks.
Pd: i guess nothing is perfect! lol
Couple of things:
- Don't have the manual in front of me but I believe our sensor is level based and not pressure based etc. That said I'd still consider any "red" warning light as important. Fill as others have stated and see if it goes away.
- Because of our setup it is important to take note and measure just how much oil you add when changing. Always a good idea but even more important for us.
- To rehash my earlier thoughts/rants would LOVE if we just had a dipstick instead of or in addition to the silly site window. If you didn't need to get the bike level to check the site window it would be OK (but still require bending way down) but as for checking while out riding etc. its just never going to be as easy as a dip stick. Over winter I'm going to see if one can be fashioned and not interfere with any moving parts. Maybe another metric bike will have one that sort of fits and requires just a little modification:)
Hey Billy, I stated once more than a year ago that I was determined to make a screw-in dipstick at the fill point on our crankcase- UNTIL- I took fill cap off and looked down inside to see engine components in the way of making a feasable dipstick to get by all of it. Take a look and see what your thoughts are. Maybe you can come up with something. 2 heads are better than one! LOL
Hummm... Just looked and I see what you mean. I'm guessing those gear thing-a-ma-jigs are important:)
I did stick a bamboo skewer down there and got a reading that way. While that would work it isn't what I was thinking!
I do remember from class that the instructor mentioned if the dipstick was rigid then you read while upright and if flexible then you read while on it's side. Seriously wouldn't want it to hit the gears but what if we had a flexible mount at the cap(like a ball-n-socket joint) and then a weight at the end(slightly bigger than a BB) to keep it down there in one position.
Problem I see is that if we turned right it might get sucked right into the gears. Any possibility we could just take left turns everywhere:)
In hindsight I now get why this was missing. Always seemed like an odd thing to leave out. Never saw this as a cost cutting measure that would have made sense.
Another thought would be if somehow we could create a tube/tunnel that would be rigid and have the flexible dipstick ride in that. No gear sucking that way but would need to figure out a way to orientate it such that it wouldn't move and throw off the reading.
Still would love to make this work since the current setup is far less than ideal:(
Just turning out to be more of a PITA than I thought.
Hey Billy- next time I change the oil and have the crankcase empty, I will look in there and just maybe your tube idea off to the side where a flexible dipstick could be housed might work. Thanks for the collaboration. Take care.
Oil light on problem
I just did my first oil change on my 2014 Stryker after 600 miles. I had the same problem with my oil light coming on all the time right after I changed it.. The level was at the top line of the site glass but it still came on... Here is what I found out...The oil light only senses low oil..Reguardless of what the site glass is telling you it is low on oil. Add a half a quart more (site glass be damned) and try riding again. Yamaha is NOTORIOUS for getting the level sensor and the site glass messed up because they set them with the motor on a bench stand and even on flat ground with the bike level the site glass can lie depending on where the level switch actually is located... Funny thing is I also had a 2001 R1 that did the same thing and Yamaha actually sent an alert to the dealers telling them to fill it a 1/2 quart past the top of the site glass because they built that motor with the site glass too low... So basically fill your bike to where it SAYS it is between the marks on the site glass, ride it, and if the oil light comes on add 1/2 a quart...
Thats why most of us forget the manual and put the full 4 US quarts in with new oil filter at change. Forget the sight glass and the manual. 4 US Quarts and filter every time. 4000 miles or at least once a year..
SMH...
Filled my oil to the proper level as per site glass, and the oil light came on. Read these other posts and decided to add some more oil. So 4 quarts in total. No more oil light.
Love this bike but little things like this are just annoying. Thank God for this forum. LOL
· Super Moderator
Yep, this ^^. I just pour in the full four liter jug each time without bothering to measure anything else. Reads high on the sight glass sometimes, but never had this issue.
1 - 18 of 18 Posts
