Installed Old No7 Shift peg today. Just cut stock peg off arm, Drilled and Taped a hole for mounting bolt and installed.
Also here is how-to for the Brake Pedal install- Took stock rubber off peg, Ground flat area in existing peg at angle desired. Made up a mount plate. Drilled and taped 2 holes to mount plate to peg. Then drilled 1 hole thru peg for mounting pedal to plate.
