PCS Lowering Connectors
10268 Views 74 Replies 19 Participants Last post by  ace
Since I could not find a good picture of these before buying, I thought it would
be a good idea to post before installing. Unlike other dog bones this design is
supposed to make it easier to lower between the 1 and 2.5 inch settings.
41 - 60 of 75 Posts
great write up. I cant wait to try this mod. I will only do the 1in tho because of the 250 rear tire.
Chubbleyum, read what PCS sent, and along with my experience and it should be easy.
Will post the pics this evening. You can email with any questions.
and now there are pictures with the instructions...
Please be aware if you use lowering dog bones and decide to increase the stock 210 tire to a 240 on the stock rim/ or wider rim you will see that the tire is larger in circumference. This will have issues with the tire hitting the frame under the rear fender. You'll find in the future that the 240 tire handles better and of course looks better. Hope this info helps!
LM
We typically do our best not to inteject on forums, but in this case we have had several calls about Low and Means comment. Using lowering dog bones will not increase your chances of the rear wheel hitting the rear fender any more than any other type of lowering assembly. As with any modification you should always know, inspect and understand the limitations of the bike with regards to the modification you are installing.
As a fellow business we would appreciate Low and Mean not making derogatory commnets about our products, or the products of other manufacturers.
You agree, through your use of this forum, that you will not post any material which is false, defamatory, inaccurate, abusive, vulgar, hateful, harassing, obscene, profane, sexually oriented, threatening, invasive of a person's privacy, adult material, or otherwise in violation of any International or United States Federal law.
Thank you and we wish Low and Mean the best with his products and business,
www.pacificcoaststar.com
dliszews, those pics made that job easier than I thought it was going to be. A big thanks to you. love the look of the bike lowered and cant wait to ride it, although i do see why you have to watch the pegs on turns.
Thank you for clearing that up. Anyone that has installed a larger tire should know to check the clearance of the inner fender. When I did this to my VTX, I had to trim the inner fender to clear a larger tire. I'm sure that's the same issue with the Stryker. I have the 240 and will be installing the PCS lowering kit. I have it....just no time to install it yet. Come on weekend!!!
I've seen a bunch of posts where guys thought that there may be a problem combining the links with a bigger tire, but I don't recall ever reading a post from someone who actually did it. I'm really interested to here how it works out for you RavenStryker. My links are on the way, but I'm still on the factory tire. Let us know your findings..........
[sub]Same here..
Just purchased Avon 250 rear..u guys think I can still put the pcs lowering links down 1"?
wow. that PCS kit really changes the geometry and balance of the bike. Almost have to learn to ride it again. feels great though to be huggin the road and flat-footed at stops is great. def worth the hour install and 50$
That's what I'm thinking too. Ive got the 250 and would want to lower 1in
I gotta see my bike back together first lol. And see how it looks with the Dunlop and low and mean fender
+1
The dynamic is definately changed. The bike leans over much easier now. First 2 or 3 rides i felt like i was weaving in the lane. I am loving this kit. Thanks PCS
With all do respect, I was not directing my comment straight at PCS, this comment was for all aftermarket dog bones for the Star Stryker. Low and Mean has completely torn down our Stryker and worked out the geometry to come to the conclusion with lowering the Star Stryker. The done bones are a great cost effective solution with the stock tire, but you will have issues with the 240 tire.
Here's what happens, the done bones do not reduce travel. Dog bones shift the travel more into the motorcycle. Which on the Stryker with the 210 tire at 40 psi and the shock bottomed out (10.25") the done bones can be 1/2 longer before the tire hits the frame under the rear fender.
We design a solid strut at 10.25" and tested all of these lowering combinations with the stock tire, the 240 tire on stock rim and 240 on the 8.5 wheel. This is solid info you can take to the bank.
The Stock shock is 12" from eye to eye. Bottomed out is 10.25", with stock done bones there's 1.75" of clearance. Install a 1/2" longer done bone and the 210 tire with 40psi will be 2mm from hitting the the frame under the rear fender. Now install the 240 tire on the stock wheel and the tire is 1.25" taller.
Your not going to feel bottoming out at low speeds this is going to happen at high speeds and hopefully the tire doesn't lock into the frame under the fender.
Again we are not directly smashing PCS and their product. We are simply forwarding this info that is a fact and everyone should know their options. And yes we do make a product that we feel is the solution with the 240 tire, it is more expensive, it is much more difficult to change, but the end result adds up and is proven facts. Here's a link to our Star Stryker lowered Spring
http://www.lowandmean.com/index.php?page=shop.product_details&flypage=flypagelm.tpl&product_id=163&category_id=106&option=com_virtuemart&Itemid=60
Sorry for hi jacking the thread, but we are just responding to PCS comment and want you guys to have the facts. Again this is not a bash on them. I have heard nothing but good things about their company. We are simply stating facts that we have tested. It would be un-ethical for us not to present a possible danger to our customer base.
No bad blood, not mad, totally respect there response, we are just here to contribute to the forum in a positive way to help all of you build your Strykers to your own style. Please anyone is welcome to contact us anytime to discuss their concerns.
Hope you all understand.
LM
L&M, When you did your testing, did you take into account making changes to the stiffness of the OEM Shock & Spring or was this only based on the original factory setting in the middle? If i read your statement correctly it sounds like the issue is if the shock compresses the full length of 10.25 then a 240 tire will hit the frame under the fender, but lets say a person weighs only 175 lbs and stiffens the stock shock & spring, I am thinking it would take jumping the grand canyon like evil knevil to compress that shock all the way to the 10.25 travel distance. Although, I dont know that for fact, I could be way off base here. Thanks
Your exactly right, most of us will never bottom the shock out at 10.25", but everyone is different in size and who or what they carry on the back of the motorcycle. I can not confirm at what point in the shock travel the 240 tire on the stock rim (with the circumference of 6'10- 1/4") will touch the frame. I do know with the stock dog bones you will be ok, complete bottom out you'll have 1/2" (This is measure not in the center of the tire but 3" from center which is the lowest point of the frame. But now lower the bike 2.25" and subtract that from wheel travel and I'm guessing you'll hit with little effort over 60mph. This I can not confirm, but doing the math it would be my best guess.
Please again, I have no intentions to take sales away from PCS, my sincere intentions is to help you guys whether you purchase from us or not. This is the info we have on hand.
One more thing, there's no clearance issue with the 240 tire on the stock rim as far as width, it when you install the 240 on a 8.5 rim that you will need to notch out the lower belt guard, but the cut is easy and everything else clears fine.
LM
Thank you for your honest answer and opinion L&M
41 - 60 of 75 Posts
