1 - 2 of 2 Posts
How can I check to see if my auto tuner is working properly? What should lights be doing on PCv and the Pcv auto tuner. Should I still get my bike dynoed if I have an auto tuner. I recently pulled baffles out of cobra swepts. It seems to run fine but backfires a little on deceleration which I heard is normal with high air flow exhaust.
Yeah, put it on a dyno...make sure your done messing with the baffles, airbox and what not. If you have the cobra swepts, take the baffles out and drill a hole in the center through both plates to get the dyno rod in far enough. It makes difference.
Call tech support first! They can log on and see what your bike is doing and tell you all that you need to know. Great service.
1 - 2 of 2 Posts
