1 - 4 of 4 Posts
So I have the Blaster x tail light (came with the bike) and it's worked fine. Recently I hooked up from fork mounted LED strip turn signals and about a week later my tail light keeps going into strobe mode..
When I turned the bike off , the strobe mode would cancel and the light was back to normal. Now it is 100% stuck in strobe mode and I can't figure out how to get it to stop!!!
I have no idea what to do. Please help.
I went on the website and it says there's some type of programing switch that comes with the light but I don't see that anywhere. No idea how to fix this....
The front turn signals I bought only came with 2 wires. Ground and flash. The lights do not run amber, they only flash amber. So I only hooked up the flash wire and ground. I capped off the blue run wire. Could that have interfered with the tail light?
It sounds like you have the front turns not wired correctly. Here is the troubleshooting from BlasterX.
123487
There is a grey wire ( if memory serves me correct) that you must touch to ground to enter program mode, then you cycle through it by grounding the grey wire just for a split second to see the next flash/strobe program. I will take a pic of instructions later tonight.
1 - 4 of 4 Posts
