1 - 14 of 14 Posts
Okay...yet another phone,,,and yet another 1 month delay on the Cobra CVT. Not to take
away from their responsive customer service, but delivery sucks and Northeast riding season
is too short. So, I am giving serious thought to the alternative, and having searched all the
posts would like to get the straight scoop on the PC V w/ Auto Tune from those that have it
installed.
Specifically, address these questions - did the O2 sensor fit the stock exhaust bung? did you
order the single or dual channel add on? How much cursing was involved in the install? And
most importantly.....are you happy with the results?
Thanks in advance.
I installed a PCV. I cant help you out with the Auto tune since I didn't get one...although I'm considering it. I can say that there was some cursing involved :) Plastic conectors and I do not get along very well and the injector clips were the worst even with the tank off.
On the plus side I'm happy with the PCV and in case you didn't see my post in the other threads on the subject...
The cheapest I have found PCV-$269 AutoTune=$200
http://hardracing.com/POWERCOMMANDERS/YAMAHA.htm
Great find...thanks for saving me the money on the tuner...wow that's crazy how much of a cost difference..hope it works out for me.
I have the PCV and the autotune, but have yet to install the autotune. The original 02 sensor has to stay in the exhaust for the 02 optimizer included with the PCV (This controls the closed loop section of the map). An additional 02 sensor is included with the Autotune which you will have to weld an additional bung into the exhaust in addition to the existing one. I am going get a new exhaust before I do this mod.
By the way, the PCV is a Fuel And Ignition tuner, so incorporated with the autotune is an unbeatable combination.
My brother has the PCV and the autotune on his '11 Vmax with awesome results.
This is not exactly true... The Dynojet PowerCommander V Autotune module uses the existing O2 sensor hole. You replace the stock O2 sensor with a wide band sensor, but you do not use both. They do have a dual channel Autotune module... but it is for bikes that came equipped with 2 O2 sensors. here are the instructions:
http://www.powercommander.com/downloads/UserGuides/AT200/AT-200.pdf
Also looked thru the Stryker service manual.. it says the O2 sensor is an M18 thread size...
The manual reads like you can simply replace your preexisting sensor with their new one, so long as the threads are the same. If that's not the case then I'll go with cobra instead.
Kov68 said:
Nope, you will have to use both 02's, I contacted Dynojet tech support to confirm this.
OK... I contacted Dynojet... Rick stated that on the 2011 Yamaha STRYKER you DO NOT use 2 O2 sensors... he said the ONLY instance this would be the case is IF it came with true 2 into 2 pipes that utilize 2 O2 sensors. As far as I know ALL STRYKER aftermarket pipes are 2-1-2 pipes.... anyone know different?
Ok..just to fix this...hardracing had them listed on the website for that price but then came back with a price of 369+ ship...so I went to http://www.superbiketoystore.com/cr...nder-PCV-Yamaha-Stryker-2011-/prod_22493.html 349.00 shipped. best I could find.
1 - 14 of 14 Posts
